Full Range Array
A friend just completed a 16 per side column for live sound use for a 4 piece acoustic guitar/vocal group using these
https://www.parts-express.com/pedocs/specs/292-614--visaton-sl87-fe-8-spec-sheet.pdf
The rising response made for easy shaping with 4 bands of PeQ. The Poly cone is really easy to listen to and softens sibilance and sssss on vocals nicely. Cheap driver too. These are supported on the low end with 2 twelve inch subs per side though…..necessary for them to be able to work at high SPL and maybe a deviation of what you may want or enjoy at home. The arrays are high passed at 100hz and allows them to play obnoxiously loud.
