where did you order your FX-D802?
From China, namely from AliExpress. I've seen same D802 on Taobao cheaper, but Ali is more comfortable to use.
There is a new model: FX-Audio D802C
Many units has been sold, many customers seemed to be very happy.
Do you think it will sound any better?
http://world.taobao.com/item/14222517161.htm?spm=a312a.7700714.0.0.rsxzAD#detail
Are these ST326 amp audiophile grade amp like T-Amps ?
I have been out the scene for awhile and saw someone praising about these FDA amps
well...
Not sure T amp are audiophile, but I think ST326 is good value for the price. You have what you pay, like T amps...
????????D802C ?? USB/??/??/??/AUX?? 80W*2-??????
You can understand Chinese, sound is good for digital source, but poor for Aux and analog source.
Another happy camper here
I've just received and hooked up one of the FX D802 amps. Feeding it HD digital in via co-ax as the analogue input is reputedly not good.
First impressions are that you would have to be very critical not to like this little amp. Output before distortion reaches audible levels is I think well short of the claimed 80/50w max but its completely clean up to well over any volume I can get away with playing at home. That's in a medium size room with some small 96db speakers not stuff specially selected for tiny amps.
Out of the box its set up with loads of bass and treble that for thirty seconds or so actually sounded pretty nice. After that I set eq to flat, bass & treble at zero and settled down to listen. This little amp provides a very clear, detailed and analytical listen throughout the range but it is real detail not just over prominent treble. The level of base control is impressive with tremendous resolution of dynamics and resonance for deep acoustic drums.
So, what don't I like about it? There was something a little odd going on with sibilance on one track, but not any others so far, and I'm not 100% sure I prefer the super detail style reproduction to the more integrated reproduction with my old valve gear - this is a bit unfair as we are talking about a 50:1 price difference here. Unless you are much younger than me and have better eyesight the small display is really difficult to read but that's the worst criticism I can find for it so far.
A very interesting and enjoyable foray into new amp technology without spending much money 🙂
The jbl lsr 3-series professional active monitors use these chips for electronic x-over and amplification. But only analog input via additional ADC. You can google "lsr305 teardown" for details and photos
impressions - fx-d802 vs i.am.d v200
I've recently aquired a v200 as well when I had a spot of bother with the fx-d802 and couldn't persuade it to play for a while. So that does give me a chance to report how they sound in comparison, both with their bundled 24v supplies.
v200 - has an aux input if you need analogue in, has more power available before it starts to distort, display and control logic slower and less intuitive than the d802. can't grumble at all at the sq for the price.
d802 - this still amazes me in how realistically acoustic instruments are portrayed and I still get shivers down the spine at times with this playing well recorded music. You absolutely must have the DSP switched out to hear this though though, DSP in use and the magic instantly dissapears and it becomes just another decently competent amp.
I'm glad to have my d802 running again 🙂
i tested SZ80, d802, D8 alientek, qa100 and D310
i think the better is D310 and qa100 with texas tas5631b and tas5231
I'd love to see a China amp/board come out with USB programming of the EQ and crossover sections of these chips.
I used to think the same way but have regrettably come to the conclusion that the first thing you have to do with any of these cheap integrated DSP amps is to turn the DSP off - as soon as they are in use all the life and detail seems to disappear from the music.
To be transparent something a lot better seems to be needed for crossover/EQ via DSP. I'm (very slowly) working up a PC (actually Odroid SoC) active crossover here.
hi Guys
All great stuff if I could understand it.
I seem to understand that these digital only amps could be the way to go.
What about the D.Sound D400 - D.Sound | Products | D400
I am still leanring and all this is very new...so please excuse my comments.
Any suggestions? So I understand now I do not need a DAC - this should be good??
Yes, you don't need a DAC. D400 looks like but it lacks optical input - so you might have noise issues due to ground being shared with the source.
Sir
Thank you for confirming I will not need a DAC. Not that I understand the physics, but if such a thing exists, I will accept its function without too much questioning.
Surely this is a good thing?
But I agree optical input would be a great option.
So is there a better option?
DAC chain:
Digital PCM -> DAC -> Analog -> Class D AMP ADC -> PWM -> Speakers
Digital chain:
Digital PCM -> Class D AMP PWM -> Speakers
There are some alternatives with optical input like Chinese amps with STA326 chip.
Digital chain:
Sir - WOW......
If there is no DAC and you can pick up a STA326 chip amp for USD65 on eBay....is this correct?? Seems too good....
Do they sound good...?? I am no audiophile (meaning I have little money and love value)....so this is like opening the candy store???
I am sure it is too good to be true??? Tell me I am dreaming.
It would be hard to tell any difference between a quality DAC/AMP and a fully digital AMP. Keep in mind that room plays a major role in sound quality, it you are using a PC-based source I suggest looking into digital room correction.
Sir
I must have been living under a rock....this is great news.
But they are rather hard to find.....???
I am thinking of miniDSP for the room eq. But I am a dinosour with all pro-audio 19" rack stuff....So moving on is hard. Old Dog New Trick stuff.
So call me stupid, why is not everyone burning their DAC and going full digital Amp???
Sorry for the questions. Just seems like I have found the answer to the ultimate question - 42....(Hitchhikers Guide to the Galaxy)....
DAC chain:
Digital chain:
Digital chain is missing a link
Digital PCM -> Digital to PWM converter -> Class D amp PWM -> Speakers
If the Digital PWM is not open loop, then a analog feedback is in use, and the pure digital signal is gone. It has to be open loop to be digital, but then you need a very good regulated power supply.
- Class D
- Full digital amplifier with chip STA326
