I have for sale complete kit (only chassis is missing) for assembling (gorgeous sounding) XRK FH9HVX amplifier. Kit consist of:
a) Set (2x) of XRK FH9HVX amplifer, carefully assembled with premium parts (Nichicon FG, Panasonic FC capacitors, Mundurf EVO 1,5 uF input capacitor). Output mosfets are ON SEMI FQA36P15/FQA40N25 type. All other parts equal to BOM. Set also includes (8xM3 standoffs and 4x AAVID Aluminium Oxide Ceramic washers). Weight is 200g / piece.
SOLD
b) Set (2x) power supply boards. Each board consist of 4x6800uF 63V Vishay capacitors and 8 fast recovery diodes in dual bridge configuration. Dimension of board is 115x70x30mm. Weight is 220g / piece.
SOLD
c) Toroid transfomer (1x) 500VA, 1x230Vac primary and 4x35Vac secondary voltages. It is special audio version with lower flux in ferrite core. Dimensions are 135x65 mm. Weight is 4,7 kg.
SOLD
d) Pair od Fischer elektronik heatsinks with dimensions of 300x120x40 mm. No eloxation. There are profesionally made M3 threads for FH9HVX amp and PSU board provided on both heatsinks. Weight is 1,9 kg / piece.
SOLD
If you take all kit above, shipping into EU (tracking included, no insurance) would be free. Payment via PayPal.
SOLD
SOLD
SOLD
SOLD
Link on the website: https://www.diyaudio.com/community/...onscious-100w-class-ab-for-lean-times.353512/
Can you tell me the distance between the output MOSFETs? I want to see will they fit on heatsinks from a chassis I already have
4,85 mm...if we have same distance in mind (see picture in attach).
