Title says it all...Velodybe VX-10 entry level sub for sale:
specs:
SPECIFICATIONS
VX-10
Cabinet Design Bass-reflex with built-in power amplifier
Frequency response 36Hz - 120Hz (+/- 3dB)
Crossover frequency 50-200Hz (variable)
Maximum output power 150 Watt (dynamic)
Phase 0° or 180°
Input impedance 1.2K ohm
(for SPEAKER LEVEL INPUT terminals)
65K ohm
(for LINE INPUT jacks)
Sensitivity
Speaker-Level 1.6V
Line 230mV
Speaker 10" (8.5" piston diameter)
Power Supply 120V 60Hz AC
Power consumption 75 Watt
Cabinet (H,W,D) 15" x 12" x 17"
381mm x 304.8mm x 431.8mm
Weight (approx.) 35 lbs.
manual: http://www.velodyne.com/velody...ucts/manuals/VX-10.pdf
Less than one year old. Perfect condition. $90.00 obo local pickup
specs:
SPECIFICATIONS
VX-10
Phase 0° or 180°
65K ohm
Sensitivity
Speaker-Level 1.6V
Line 230mV
