I don't recommend plexiglass, it will melt when soldered on. If you can get electrical fiberglass (G10 or the pink stuff) or phenolic, you'll have a better time. Or even just a hunk of plywood, if you don't mind the smell. Not exactly electrical anymore but it won't melt/burn as fast as plexiglass.
Tim
Tim
Tim
thanks for the tip buddy 😉
actually today I just did some laser cutting and result is much better than expected 😎
the goal was to build stand for the tags, 4x and 8x
first I have to do some Corel job. I used 4mm plexiglass, there is a mounting hole for every board, 8tagers have two extra holes at both ends to assure steady mounting. it was not necessary for 4tags ones.
I tested them for soldering, I almost hold the head of a 100W soldering iron on the tag and guess what?! the plexigalss didn't melt down at all 😀 gold plated surface let me to solder a wire for less than 2 seconds!! amazing 🙂
one thing interesting, the beneath screw of the tag will allow to attach one or two spades for underneath wiring or ground connection
some photos:
FS: Gold plated tag boards
small board with 4 tags: 1.25USD/ea.
big board with 8 tags: 2.75USD/ea.
the story of these tags:
I had some nice gold plated tags lying around:
I just thought to make some nice tag stripe to use in DIY tube gears projects 🙂 so I just hit the road going to my friend's Laser cutting workshop. first I had to do some Corel job:
and then let the Laser router do the talking:
result:
all parts are 4mm hard Plexiglass.4xs board have one hole in the center and 8xs have two extra holes at both ends to assure steady mounting:
the beneath screw of the tag will allow to attach one or two spades for underneath wiring or ground connection:
result:
FS: x4 Audio Note 211 tubes (GE)
for sale are x4 GE (rebranded to AN by Audio Note) 211 tubes. less than 100 hours.
let me know your offers
Marten Getz for sale:
bought: Jen. 2012
barely used (less than 500 hours)
never overpowered, always sounded using ~25W SE tube amps
Black Piano
with original boxes and manual and everything else
retail price: 20,000USD
I'm asking at least 7700USD shipment included.
they ship from Iran (east Asia). I'll ship world wide except Israel
I can come up with some photos if anybody mind to see some
bought: Jen. 2012
Black Piano
is there any interest in Western Electric VT-25-A tubes? I got some NOS in stock. something like this:
how about U52/5U4 rectifier tubes? they go pretty high on ebay:
- Vendor's Bazaar
- FS: Various by esl-fan
