[FS - UK] Linkwitz LX521 system - please contact me if interested
I'm still a bit unsure if I want to part with these, however I have too much audio equipment and several pairs of speakers hanging around so something needs to go (to maintain matrimonial harmony!).
Looking for £2500
These are phenomenal speakers, constant directivity, true full range (20Hz to 20Hz). I tested them against Wilson Watt Puppies, KEF R3, PMC twenty.25, Troels Gravesen 3WC-15 and these where by far my favourites. You'd have to spend some serious money to equal these if purchasing a traditional commercial speaker.
The only thing you need to be aware of is that these are open baffle speakers - you need to be able to position them out into the room by 1.25m to have the best sound quality. Recommended room size is 25m2 or larger - these speakers are capable of serious volume levels without distortion!
LX521 Description
These have been built exactly to the LX521.3 specification. Original build manual will be provided with the purchase.
Included in this auction:
Pair of LX521 speakers - mdf with oak style veneer. 12 seas drivers installed
(see:
Madisound Speaker Components ... 4-way-kit/)
Sommer Elephant 8 core speaker cables terminated with neutrik plugs - I have a number of pairs, including some 4-5m long. Should be enough for all siting options.
Pair of amplifiers (each amplifier containing three channels of amplification: a stereo LM4780 feeding mid and tweeter, and a single channel Hypex feeding both woofers)
Analogue signal processor (ASP.3) that takes analogue output (XLR or RCA) from your source and splits it to each amplifier channel.
The above is a full active and working system, just add your source/preamp.
