FS: Turntable-Motor +Controller
Joined 2004
---SOLD---
Maxon DCX22 L
DCX 22 L Ø22 mm, Precious Metal Brushes CLL, ball bearings
48V; 27,8mNm
DIY Motor-Controller
DC-Motor controller
Containing: AD707 (CERDIP), REF02, OPA548
Schematic provided
Pulley
Origin Live Short Pulley - high grip TMPA2
or
high precision 10mm Aluminium pulley from a group-buy of a German forum
Belt
Origin Life Rubber-Belt ca.350mm diameter and/or some meters of (mylar?) tape (from tape machine; ends can be connected with adhesive tape)
Prices:
Motor 120€
OL Pulley 15€
Alu Pulley 25€
Motor Controller 25€
Belt: free with controller/pulley
free Mounting-plate milled out of 1mm FR4-board material
Everything: 160€
+Shipping
First: This is a high-end DC-Motor but it is noisy. Therefore, it must be installed in an appropriate housing. This is because of the ball-bearings.
I made a TT motor controller with a Maxon motor with more silent sleeve bearings before and the bearings did not last. So this time I decided for ball bearings with their noise-penalty.
The controller has a negative output resistance, which equals the winding resistance of the motor.
Look up the articles of Mark Kelly, Application Note sboa043 or this: https://www.precisionmicrodrives.com/ab-026
REF02 voltage reference, switchable between 33 and 45rpm, both adjustable, OPA548 output device
The speed stability and -regulation are excellent- it is almost impossible to stop the motor with a finger touching the pulley.
Input Voltage ca. 24…40V
I used it in a WellTempered Amadeus and it was an incredible upgrade.
Motor+Mounting+OL-Pulley+Controller:
Pulleys:
Belt/Tape:
---SOLD---
