FS: Trans-Fi Terminator linear tracking air bearing tone arm
This is a complete package, which includes absolutely everything to operate the tonearm - the complete tonearm itself, the wands to hold cartridges, air pump, smoothing tank, extra tubing, extra wires. You will get 6 wands to mount six different cartridges. You will get extra wire to connect the cartridges to Molex connector. You will get the "VTA on the fly" gauge, if you are really picky about that parameter. You will be amazed how much better it tracks the grooves than most pivoted tonearms, no matter the cost. There will be no inner groove distortion, and no need to futz around with protractors.
The only thing that you will possibly require is the mounting column, depending on the thickness of the platter on your turntable. Any machine shop can make you one, if you need one that's longer that I'm including.
Cartridges and the turntable are not included, they are shown only for reference purposes.
The tonearm is ready to be assembled, provided you will have the proper height mounting column. Don't be freaked out by all the little weights, wires and screws: these are all just extras, that you'll probably never need.
Set-up instructions are very easy for those with modicum of mechanical sense, and are available on the TRANS-FI website.
Trans-Fi Audio - MANUAL
$XXX includes postage in the USA.
SOLD
