For sale, in new or like-new condition (no solder, never mounted):
Four Tangband 8" neo subwoofers, model W8-1363SB, $50/each or $90/pair or $160/four plus shipping. Used in a low-tuned vented box of about .75 to 1 cubic feet, gentle initial slope to rolloff over most of bass region is the approximate inverse of room gain, resulting in more balanced in-room response. This is how I design my commercial subwoofer system, the "Swarm". Use in scattered multisub system for best results. http://www.parts-express.com//pe/sh...tnumber=264-833
Two discontinued 250-watt plate amps from Parts Express, $60/each or $100/pair plus shipping. http://www.parts-express.com//pe/pshowdetl.cfm?&Partnumber=300-794&CFID=13414389&CFTOKEN=71061864
Two ultra high power handling Ciare 12" prosound subwoofer drivers, model 12.00SW, 4 OHM VERSION. Fs = 44 Hz; Qts = .38; Qes = .40; Vas = 32 liters, Xmax = 11.5mm; program power = 2000 watts(!). In a 2 -2.4 cubic foot low-tuned vented box, the gentle initial slope to the rolloff over most of the bass region is the approximate inverse of room gain, resulting in blanced in-room response. This is how I design my commercial subs. $150/each or $250/pair plus shipping. Go to US Speaker's homepage, click on "Ciare" across the top, and scroll down.
http://www.usspeaker.com/homepage.htm
You can check my feedback on Audiogon, username "AudioKinesis".
Thanks for taking a look.
Duke
audiokinesis at yahoo dot com
Duke
