For sale one Adire Audio Brahma 15D4 XBL^2 subwoofer. Acquired new but never used, in good condition, and has only had power applied for testing.
15" with dual 4 ohm voice coils
Fs 18 Hz
Qms 12.7
Qes 0.55
Qts 0.53
Vas 265 L
Re 2x2.8 Ohm
Le 2x0.8 mH
Sd 740 cm2
BL 16
Xmax 28.5mm one way linear
Pmax 600W RMS (actual will depend on your application)
SPL 86.2 dB @ 1W, 1m
$225 plus shipping from 98177
weight approximately 35 lbs.
Fs 18 Hz
Qms 12.7
Qes 0.55
Qts 0.53
Vas 265 L
Re 2x2.8 Ohm
Le 2x0.8 mH
Sd 740 cm2
BL 16
