Hi all. It's been quite some time since I've been around, but I have a unique set of speakers that I wanted to offer. Please don't hesitate to get in touch if you have questions.
I've owned these for the last 7 or 8 years and they've performed spectacularly. They are undoubtedly unique and rare. My understanding is they use an edge driven styrofoam panel as well as a dome tweeter. Beyond that there is very little information to be had. what i do know is given some space they produce an incredible image and fantastic quality down to the 60-80Hz range. You'll need a sub with them for sure.
I'm asking $400 + shipping. You're also welcome to pick them up north of Seattle.
Photos here: https://plus.google.com/+SteveStrong1/posts/XibjrxjeHHt
Specifications:
Recommended Amplifier Power: Up to 100 watts
Frequency Response: 80Hz - 20kHz +/- 3dB
Impedance: 4 ohms
Sensitivity: 91 dB @ 1 watt/ 1 meter
High Frequency Crossover: 2.5kHz
Driver: 2 HDC panels
Height: 41"
Width: 17"
Depth (at thickest point in speaker) 3"
Depth (at thickest point in base) 8"
Weight: 32.5 lbs
Wood Veneer: Black Ash
Enclosure Material: Aluminum
Enclosure Type: Open aluminum frame
Manufacturer Description:
The remarkably thin and stylish Klayman Signature speakers from SRS Labs will captivate both your eyes and ears. The furniture-quality cherry wood finish and flat profile design give the Klayman Signatures a distinctive traditional design over standard mid-size speakers while delivering spectacular sound. This award-winning design blends well into today's traditional or contemporary setting while delivering a true cinematic experience.
Think Outside The Box
SRS' line of speakers eliminates the need for bulky wooden speaker enclosures like those used to house traditional cone-shaped drivers. Molded from High Density Cellular (HDC) materials, our flat panel speakers are 0.32" thick and less than 1.5" total depth when mounted in their frame. This design marvel helped us to sculpt a finished design that is 3" in total thickness at its widest point.
Focus on Sound
Flat panel speaker technology has been around for quite some time however, previous designs have lacked a wide dynamic range of sound without considerable distortion. To overcome this challenge, SRS speaker panels utilize Focus Rings which enable the panel to flex and move the energy evenly and accurately and across the surface. These rings are etched into the front and back side of the panel at precise intervals; highs (inner ring), mids (second ring) and lows (third ring). The panel can then be fine-tuned by adding or subtracting weight within the rings to reproduce the desired frequency response.
Greater Sound Coverage
Experience our speakers for the first time and you will no doubt be amazed how efficiently they fill the room with sound. One way we accomplish a much wider sound stage is through the shear mass of the speaker driver which employs 108 square inches of radiating surface. The larger area generates a much wider dispersion of the mid to high frequencies virtually eliminating the sweet spot..
Specifications:
Impedance: 4 ohms
Height: 41"
Width: 17"
Weight: 32.5 lbs
Focus on Sound
