SoundSplinter Rl-p15
I have a barely used SoundSplinter Rl-p15 dual 2 ohm voice coil subwoofer for sale. I used it for about 6 months in a home audio setup and less then a week in my car. It is in perfect condition (surround is perfect, no rust on motor, etc.) with the exception of some slight caulk on the bottom of the gasket.
$200 + actual shipping (40lbs, 18x18x11)
SPECS:
Dual 2 Ohm
Qts: 0.333
Qes: 0.363
Qms: 4.032
Fs: 23.426 Hz
Re: 3.66 Ohm
Ls: 5.236 mH
Rp: 10.46
Vas: 163.0 L
Mms: 290.9 g
Cms: 158.6 u
Bl: 20.76 T*m
SPL: 89.43 dB
Sd: 0.0806 m^2
Xmax: 24.6 mm
Measurements
Mounting Depth: 17.5 cm
Total Depth: 18.5 cm
Outside Diameter: 31.8 cm
Weight: 35 lbs
Magnet Width: 18.8 cm
Mounting Cutout: 35.5 cm
Displacement: 0.18 cu ft
(click the thumbnails)
SPECS:
Dual 2 Ohm
Qts: 0.333
Qes: 0.363
Qms: 4.032
Fs: 23.426 Hz
Re: 3.66 Ohm
Ls: 5.236 mH
Rp: 10.46
Vas: 163.0 L
Mms: 290.9 g
Cms: 158.6 u
Bl: 20.76 T*m
SPL: 89.43 dB
Sd: 0.0806 m^2
Xmax: 24.6 mm
Measurements
Weight: 35 lbs
