FS Seas T35C002 dome tweeter
Selling the new Seas T35C002 dome tweeter, only 1 tweeter available.
Item is new, never used, soldered or connected to anything, in the original box.
The T35C002 is a classic dome midrange tweeter with high sensitivity and a smooth, extended frequency response. A coated fabric dome with integral surround manufactured by Dr. K. Müller in Germany ensures excellent performance and consistency. This supplier was among the first in the world to offer fabric dome diaphragms, and did produce the diaphragm for the famous 1.5” Dome Tweeter H087, developed by Seas in 1968. A small, high efficiency Neodymium ring magnet in a carefully designed system contributes to high sensitivity and low distortion. The top plate and T-yoke are CNC machined for excellent precision. A well damped vented pole and a rigid rear chamber ensure a low resonance frequency and smooth response. A generously underhung 35mm voice coil wound from copper-clad aluminum wire further enhances the sensitivity. Flexible lead-out wires and venting holes in the aluminum coil former help reduce noise to a minimum. A 7mm thick precision die-cast aluminum front plate with moderate horn loading ensures linear frequency response and represents an extremely stable platform for the magnet system and the moving parts.
Specification
Nominal Impedance 6 Ohms Recommended Frequency Range 1500 - 25000 Hz
Short Term Power Handling 250W Long Term Power Handling 100W
Characteristic Sensitivity (2.83V, 1m) 95.0 dB
Voice Coil Diameter 35mm Voice Coil Height 2.0mm Air Gap Height 3.0mm Linear Coil Travel (p-p) 1.0mm
Voice Coil Resistance 4.6 Ohms Voice Coil Inductance 0.06mH
Force Factor 4.3 N/A
Free Air Resonance 620Hz
Moving Mass 0.47g Effective Piston Area 11.9cm2
Magnetic Gap Flux Density 1.6T
Magnet Weight 35g
Total Weight 0.37kg
160 USD + 20 for shipping.
Paypal, buyer pays fees
