FS: Salas Folded Simplicistic Phono Stage + Paradise Preregulator
For sale Salas Simplicistic Phono stage LMC 63db version with Teabag Pcb's, Nichicon Muse capacitors and MKP1837, all parts from Mouser. Silver mica and K73-11 signal capacitors. Load resistors are generated by an LDR resistor replacer.
The phono stage is powered by a Paradise Pre-regulator from GB Diyaudio, a small LDR power supply has been added. The original BLOCK transformers are not rigidly fixed to the PCBs and foam and lead have been added to make them even quieter.
The whole is connected with a professional connector, is perfectly functional and sounds great. I am selling it for lack of time. In the last 2 years I turned it on about 10 hours in total.
In the state in which it is found in the photographs, I sell together for 350 330 euros + shipping and Paypal fees.
Best regards
Guglielmo
Italy
Best regards
Guglielmo
Italy
Hi Guglielmo,
If I'm correct 63dB is the maximum amount of amplification, do you think it is enough for a Benz micro Ace Low output (0.4mV) MC cartridge?
What would be the price sending everything except the case to Bangkok, Thailand?
Cheers Maikel
