FS: Salas DCB1 Mezmerize
Sold pending funds
Salas Board DCB1 Mezmerize built with quality parts and heatsinks.
This is Hotrodded to ~250mA, the sinks get warm but never hot to the touch.
Film resistors, Omron relays, Gold tone & Silmic II caps, LEDs were matched, 6 channel Electroswitch selector with lights (easy to desolder leads if you don't want to use indicator lights)
Heatsinks are included but will be removed for shipping.
Case is NOT included.
Working when pulled. I bought a Nad DAC with volume control, so DCB1 is no longer used.
$50 plus shipping. USA CONUS only.
Ron
Carlthess40,
The phono section was MM, and is an excellent phono preamp. I am using it for a Denon DL-110 HOMC . Sounds wonderful. I'm sure it sounds as good with a MM cart too.
It is the CNC phono preamp , I think you can still get the boards from Sachu888 on the SwapMeet forum. Low parts count and you can swap opamps to find the sound that matches your system well. AudioKarma has lots of info on these great little boards.
Good luck
Ron
