FS: Proac Response 2.5 clone, crossovers.
For sale, in perfect working condition, the crossover for the DIY Proac 2.5
Now, the crossovers have been put up for auction on ebay:
http://www.ebay.com/itm/26127676076...l?_from=R40&_sacat=0&_nkw=261276760762&_rdc=1
The crossover is based on the Troels Gravesen design for the Scan Speak 9500 and 8535, with crossover frecuency at 3KHz.
I sell it because I have upgrade the speakers to active bi-amp with active filters.
All components are high-end as you can see listed below. Only the components value are far over 250$. The board has been protected in the cooper side to prevent oxidation.
SOLEN 8.2uF-400VDC POLYPROPYLENE CAPACITOR
AURICAP 4.7uF-400V CAPACITOR
MILLS 2.2R 12W MRA12 Resistor (RES-M1100)
MILLS 10R 12W MRA12 Resistor (RES-M1180)
MILLS 4.7R 12W MRA12 Resistor (RES-M1135)
JANTZEN 1.80mH Jantzen Audio Cross Coil
JANTZEN 0.47mH Jantzen Audio Cross Coil
JANTZEN 0.22mH Jantzen Audio Air cored coil
Contact to Ignacio: ivigueras@terra.es
You can see my seller and buyer profile in eBay. User: ivigueras. http://myworld.ebay.es/ivigueras
