FS Philips TDA1541A R1 and Philips TDA1541 DAC chip
I have one spare TDA1541 and TDA1541A R1 which I pulled out from Marantz CD40 and Marantz CD65. Both tested working fine.
I like to try TDA1541A S1 and need extra cash. International postage availble. Paypal welcome. Item located in Australia. Each $80 AUD or $60 USD.
Interesting that you've got the Abbas board. Uses lots of nos as well as germanium stuff.
How does it sound ? Share something with you, output of dac to analog try to use very thin solid core wire like good Cat5e gauge & listen again goes for analog to rca sockets as well.
Cheers
Good that it works for you too. Can't say too much for not I'll get bombarded. Lol
Sorry S1 are for keeps. I also see that you using Johns recommendation of 100uf caps
for the 14 caps is correct ? Tested it & didn't work for my set up.
Cheers
My caps are different. See photos. I changed to RCA 5692 red base and valve rectified b+. Next level midrange and vocal😀
I think Abbas uses a type of active I/V if memory serves me correctly.
Edit: a friend here in Brisbane has a 2.2SE Abbas, and it sounds lovely, best DAC I have heard for realism, he tried a couple of S1 chips in his and preferred it with the R1 it came with, might be as Abbas designs with it in mind. I went with a late standard Taiwan A chip over some S1's as the Holland S1's were a bit dark in my modded Marantz, but could be my preferences due to system balance.
Good luck with the chip sales.
