FS: Peerless 10" XXLS Woofers, Pair
For sale is a pair of Peerless XXLS 10" cast frame drivers, model 830786, in great shape. They have very little actual use on them, and will ship in their original Styrofoam boxes.
$160 / pair plus actual shipping
Manufacturer's Specs follow:
Electrical Data
Nominal impedance Zn 4 ohm
Minimum impedance Zmin 2.2 ohm
Maximum impedance Zo 26.5 ohm
DC resistance Re 1.7 ohm
Voice coil inductance Le 1.5 mH
Capacitor in series with x ohm Cc -- uF
T-S Parameters
Resonance Frequency
fs 39 Hz
Mechanical Q factor Qms 6.79
Electrical Q factor Qes 0.47
Total Q factor Qts 0.44
Force factor Bl 10.4 Tm
Mechanical resistance Rms 4.37 Kg/s
Moving mass Mms 121.1 g
Suspension compliance Cms 0.14 mm/N
Effective cone diameter D 21.2 cm
Effective piston area Sd 352 cm
2
Equivalent volume Vas 23.6 ltrs
Sensitivity (2.83V/1m)
92.2 dB
Ratio BL/¥(Re) 7.9
Ratio fs/Qts F 88
Power handling
100h RMS noise test (IEC) -- W
Long-term Max Power (IEC 18.3) -- W
Max linear SPL (rms) @ power -- dB/W
Short Term Max power (IEC 18.2) -- W
Voice Coil and Magnet Parameters
Voice coil diameter 51 mm
Voice coil height 33 mm
Voice coil layers 4
Height of the gap 8 mm
Linear excursion +/- 12.5 mm
Max mech. excursion +/- -- mm
Flux density of gap -- mWb
Total useful flux 2.4 mWb
Diameter of magnet 147 mm
Height of magnet 35 mm
Weight of magnet 2.4 Kg
