FS: NEW Jensen JT-11-YMPC Output Transformer 600:600 Perfect for any v-out DAC!
New and unused transformers from Jensen. FAR superior to DAC direct-out with a capacitor for DC blocking.
These high quality transformers allow you to use the entire balanced signal from your CS4397/8 or any other v-out DAC and convert it to single-ended, and block all DC offset. Huge upgrade from capacitors alone or an op-amp output stage.
Cores are made from 80% nickel, just as good as amorphous core. Sound is on par with Lundahls and Sowters. Extremely low insertion loss and incredible frequency response.
Retail is $32.16 each, will sell for $60/pair plus shipping. 2 sets available.
Specs: http://www.jensen-transformers.com/datashts/11ympc.pdf
I've uploaded a simple circuit diagram so you can see how to use them.
PM me!
