The NC500 is a high resolution, audiophile grade, mono-block amplifier with up to 700 watts output. Utilizing proven Hypex NCore® power amplifier modules, the NC500 achieves the highest quality neutral, transparent sound quality. Measured and sonic performance is comparable to amplifiers many times the price, even the very best class A amplifiers. Because it utilizes class D operation, the NC500 is also extremely compact and efficient.
I assembled the amps myself using standard Hypex modules and Ghentaudio cases. I am an electrical engineer by training. The units have been fully tested and all the electronics are fully warranted by Hypex for two years.
The input buffers are standard Hypex. They can be easily bypassed and then driven directly by any preamp that has sufficient gain (10 - 15 db) Or, custom made input buffers can be used. I have bypassed the input buffers and driven the amps directly and found a slight improvement in sound quality. I can ship the amps with the buffers bypassed or not.
These amps utilize the identical Hypex modules as the Acoustic Imagery Atsah 500 and Nord amps. The Atsah received a 5* award from Hi-Fi Choice.
Features
* Ultra low noise and distortion
* High current output capable of driving 2 ohms for the most demanding speakers
* XLR balanced, fully differential input (adapter required for RCA input)
* 100% aluminum black case with 8 mm front panel
* Extensive, microprocessor-controlled error protection
* LED power light can be turned off or set to two different brightness levels
* Genuine Hypex NCore NC500 modules
* Genuine Hypex SMPS1200A700 power supplies
* Genuine Hypex input buffer boards
* High quality Ghentaudio cases
* High quality speaker binding posts accept banana plugs, spades, or bare wire
Technical Specifications
* Power output: 700 Watts RMS 4 ohms, 400 Watts RMS 8 ohms, 550 Watts RMS 2ohms
* Distortion: THD+N, IMD - 0.001% typical, Max .005%, 20Hz - 20kHz, Pout/2 or less
* Signal to noise ratio: > 130 dB (Re full power)
* Frequency response: 0 - 50k Hz +0/-3dB
* Input impedance 47K
* Efficiency 93% at full power
* 25 watts idle
* Weight: 6.5 lbs
* Dimensions: 3.0"(H) x 8"(W) x 12"(D) (includes feet and binding posts)
Please feel free to call me at (831) 531-7077 for more information.
Features
* 25 watts idle
* Weight: 6.5 lbs
