FS: MFOS-WSG Synth Kits (Music from Outer Space Weird Sound Gen)
Some time ago I built circuit boards and bought parts to make three Music from Outer Space WSG kits. I built up one for myself and the other two sat on a shelf.
The WSG is a compact six-oscillator, four-voice normalised analog synth with a very effective filter.
But I still have the two kits and they need to find homes. The kits contain: All necessary switches, pots, jacks, knobs & hardware plus a built circuit board. You supply your own case / panel and wire.
Asking $35 each, plus shipping (cheap).
Do you have a manual as well? I’m in for one then.
I have a sheet that indicates all the attachment points on the board and the rest of the docs should be available on the MFOS site. I'll see about putting something together - but if worse comes to worse, I can always document my build.
ETA - I dont see all the docs, just a panel diagram (which is all you should need with my sheet). I've sent a mail to Ray to ask about the rest.
Correction - all of the docs are on the MFOS website, I was not looking in the right area. Go to the broader WSG section and look at "panel wiring type 1" and "PC board, Andrew Sharp version".
Everything you need is there.
