Went shopping for some toys and ended up with bigger lots than I needed for my own consumption.
UFW-12 Subwoofers - Single Coil 4-Ohm. Specs make it look ideal for sealed box or IB use. This is an uber-quality OEM driver purportedly used in a $1K home sub. Reminiscent of an Oz Matrix Elite or IDMAX.
- Cast Aluminum Basket
- Voice Coil Cooling Vents in the basket
- Appears to be a carbon fiber cone and dustcap
- Fat foam surround stitched to cone
- Gold Spring-Loaded Terminals
- Double Stacked Magnet
- Vented Pole Piece
- 3" Voice Coil
- Tinsel Leads sewn down to Spider
- Weighs 25.3 pounds net (sub only)
WT3 results and T/S parameters coming. $100 delivered per sub in the Continental US. Quantity of 10 available.
1" Aluminum Cone Tweeters with Fabric Surrounds - Specs from the WT3 coming. New in the original boxes. $33 per pair delivered CONUS. Lots available.
Toroid AV-2002B, 120VAC Primary, 15V-0-15V (0.5A) and 51V-0-51V (5A) Secondaries. $33 Delivered ConUS. Several Available.
Toroid YD-022RT, 120VAC Primary, 15V-0-15V (0.5A) and 38V-0-38V (4.5A) Secondaries. $27 Delivered ConUS. Several available.
I'll make another post for the 10" woofer so I can add pix of it too. Please reply to thread with any interest. Payments via PayPal, shipping will be Postal or Fedex with Tracking. I can provide positive references from other forums.
- Vented Pole Piece
- 3" Voice Coil
