FS: Loaded Dynaco PASS PC6 phono pcb
Fully stuffed and loaded Dynaco Pass PC6 phono stage. Not your plain Jane PC6, this board has the RIAA components and circuit modified per Joe Curcio mod document. Carbon comp grid stop resistors, carbon film plate resistors, Sprague 730p film coupling and out caps. Matched RIAA components.Teflon tube sockets. Each channel HV section is separate and regulated with a LR8, and each channel ground is separated. Heater section is regulated with a L7812. Also included on board is a Le Pacific MC pre preamp with low noise Fet (NTE1458...2SK170 clone), that runs off of the 12V regulated heater supply. Large 1uF Sprague 730p film output caps. Mod document and schematics included. Not a pretty board, but works fine. $100.00 plus shipping.
