(24) Foster wide band drivers
8 ohm
87.3dB
Fs 80.7Hz
Vas 10 liters
Qms 4.267
Qes 1.375
Qts 1.040
BL 3.57
Cms 808.7 uM/N
Mms 4.81g
Re 7.2 ohm
Krm 1.155
Kxm 6.832
Erm 0.818
Exm 0.716
Sd 0.0094 sqM
Le 0.57mH @ 1kHz
Probably best used free air.
25W power handling each
(60) Dayton ND20FA-6 3/4" Neodymium Dome Tweeter
Specifications: *Power handling: 15 watts RMS/30 watts max *VCdia: 3/4" *Impedance: 6 ohms *Re: 5.2 ohms *Frequency range: 3,500 - 25,000 Hz *Fs: 1,800 Hz *SPL: 92 dB 2.83V/1m *Dimensions: A: 1-3/4", B: 1-5/16", C: 3/4".
* Compact neodymium motors have low stray field
* Ferrofluid enhances power handling and helps damp resonance
* Front-mount pressfit design
* Center-to-center spacing as low as 1-3/4"
* Extremely flat and extended response
All working with short wires soldered to terminals. ready for your line-array project - $200.00 plus shipping from Ohio
