Because I have no use for it anymore I'm selling my LDR attenuator based on buildanamp.com Lighter Note.
I have owned a few passive preamps and this one beat them out by a large margin
The preamp uses ldrs like the lightspeed preamp.The volume set at zero, you will still hear some sound,it’s in the design and never bothered me.
As you can see it's very high build quality and parts and has a custom made front panel, transformer is for both 115V or 230v mains.
Asking 195€.
Asking 195€.
Beautiful build again! Still the recommendation to connect the casing to PE as it has a 3 pin IEC with PE and the case is metal (so it should be connected for safety).
