FS: Lambda TD12M Woofers $295(pair)
Lambda TD12M Woofers $295(pair) plus shipping (US only)
VERY low inductance motor with shorting rings and extended HF response.
I purchased these new. These were only used for testing but are a bit dusty. The surrounds are tacky and attract dust.
Specs
TD12M - 8ohm
Fs: 38.1Hz
Qms: 2.99
Vas: 140L
Cms: .35mm/N
Mms: 50g
Rms: 4kg/s
Xmax: 6mm
Sd: 531sqcm
Qes: .27
Re: 6.6ohm
Le: .2mH
Z: 8ohm
Bl: 17Tm
Pe: 500W
Qts: .25
1W SPL: 96.5dB
$295.00 for the pair plus shipping cost. US only.
I have one original box for sure and I think the second. If not, I have an equivalent box for a 12" driver. Those 2 boxes will be place in one larger box with bubble wrap and/or peanuts.
I can ship to someone in the US, but the shipping address on the Paypal transaction MUST match the US destination.
Best Regards,
Cedric
