FS:HPA-NXV201PS Amplifier Module - End of Line Special!
End of line September special!
Normal Price is $269.00 each - Sale price $165.00AUD each.
See holtonprecisionaudio.com to purchase.
The nxV201PS is an end of line mini mono block amplifier module. Based on the very popular nxV200, the nxv201PS is designed to meet the needs of people who want an easier solution to building their own high quality audio amplifier.
With most audio module installations, wiring the power supply components can often be a very time consuming task and it is very easy to make mistakes, resulting in either damaging the amplifier or other components. The nxV201PS takes all that pain away by providing a high quality low noise power supply built into the main amplifier PCB. It features dual ultra high speed soft recovery bridge rectifiers and 10,000uf 63v main filter capacitors for each supply rail. This provides a low ground noise high speed supply right where the amplifier needs it. As close as possible to the main output stage, eliminating long power cable runs.
100 Watts RMS continuous sine wave into 8 Ω
170 Watts RMS continuous sine wave into 4 Ω
The HPA-NXV201PS is 2 Ω Stable
Biased into Class A/B
Power Bandwidth 3.5hz to 300khz -3dB
Dampening Factor At 100hz 8Ω = 800
RCA Single ended Input impedance 33kΩ
Single Ended Input Gain = 30.6dB
SNR -105dB
THD-N = 0.005% @ 10 watts 8 Ohms
PSU Power Transformer secondary winding 35vac (225VA)
