FS : Heatsinks , Cases , FETS , ....
hi.
we have quite a few hetsinks for sale.
the profile is like the profile in the picture (not exactly but close enough to give you a good idea) and the dimensions are;
8" /200 mm wide , 1.6" / 40mm deep with 0.4"/10mm baseplate and 2.4"/60mm high (type1) or 4.8"/120mm high (type2).
we have enough for an even large group buy :)
we have quite a few cases , with the above heatsinks as side profiles , 4mm aluminium frontplate an rest of 1,25mm steel, size of case1 19" x 8" x 2.4" (483mm x 205mm x 60mm) and case2
19" x 8" x 4.8" (483mm x 205mm x 120mm)
again we have enough for an even large group buy...
we have some fets , irfp 241 , irfp 240 , irfp 250 and irfp 9240 again we would prefer a group buy....
rgds karsten madsen - www.cadaudio.dk
ps. i think the heatsinks are suitable for aleph x and other amps......
km said:
hi.
sorry , should have tested it on-line :)
seems to work now , for cases they are allready at ;
http://cadaudio.dk/amplifierkits.htm
And again you didn't, no offence but when you put a site on the net make sure it works.
following pages need adjustment
http://cadaudio.dk/hifiloudspeakers.htm
http://cadaudio.dk/audaxunits.htm
http://cadaudio.dk/other_hifiunits.htm
http://cadaudio.dk/hifiamplifiers.htm
http://cadaudio.dk/pwmaudio_en.htm
http://cadaudio.dk/hificables.htm
I didn't check everything but i guess the other one are bad to. Hint when you check online, make sure your browser cache is empty. It's easier to find faults then.
sure they work on your pc, because you have the files on your harddisk where they are redirected to.
file:///C:/cadaudio%200103/hifiamplifiers.htm
this is the url that's on your page, that goes to hifi amplifiers. But it can't do that because the link refers to your harddisk.
Watch you statusbar when you hover a link.
