FS: Fully assembled diyAudio Aleph J
Update: SOLD
This is a fully assembled Nelson Pass designed Aleph J circuit using PCBs and chassis sourced through diyAudio. Panasonic power supply capacitors and power resistors, Vishay/Dale signal level resistors, Schaffner power inlet EMI filter/fuse/switch, Silmac II input capacitors, and h_a's Aleph J JFET/MOSFET kit. The chassis is the Deluxe 4U chassis with the UMS heat sinks so many other diyAudio board projects can be used. Since the design work is of Pass and diyAudio, this is being sold at parts cost only: $825 plus shipping CONUS (35lbs from 52402).
The unit is currently configured for balanced XLR input only. I can include a pair of RCA jacks that can replace the XLRs if desired.
Build photos posted here: http://www.diyaudio.com/forums/pass-labs/241729-aleph-j-illustrated-build-guide-9.html#post3637427
