Up for sale is a beautiful made FirstWatt M2 clone in dual mono configuration!
The amp is build very special! Amp section is in a big 5U 500mm silver case and the power supply in rec case separate!
Power supply:
2x 500VA audiograde EI core transformers
16x 22000uF high grade kemet asl capacitors
4x hammond filter chokes
Output voltage is -24V +24V (little higher so more power is possible)
Amplifier section:
16x 22000uF CDE (88000uF per rail)
2x M2 clone boards
1x 5U 500mm deluxe custom pre drilled hifi2000 case
Can be used for all first watt amps!
If there is interest I can send pictures to your e-mail!
Shipping to EU only! Two separate packages! Very heavy!
Price best offer!
Power supply:
Amplifier section:
2x M2 clone boards
Price best offer!
