FS [Euro] Chassis, Heatsinks, Boards & parts...
Hello,
parts that can go, no use or project for these.
I am taking offers, even low €€€ ones don't be shy, try! You can combine, remove do all what you want, I'll be happy to get rid of these 😉
Note that I don't get the PM notifications anymore, so please leave a message here telling that you did send a PM so I'll get notified.
Shipping as cheap as I can find from France at your charge and so if Paypal fees.
Thanks for looking.
Matthieu
* 1U rack cases, steel, used, good overall shape, x2
* 1.5U rack cases, thick steel, top removable and sub PCB internal holder walls also (see screws). 2 are new protected, 4 new and never used but as unprotected show light marks. Mounting ears available as per picture.
* 2U rack case, Mettec 314-8802, aluminum, new and sadly drilled to wrong specs, M5920035 | METTEC Rack Mount Case, 2U, 88 x 482.6 x 367.5mm | METCASE
* Lab steel case, retro lab look, brand new unboxed, http://uk.rs-online.com/web/p/instrument-cases/0224032/
* small project cases, brand new,
* 1 pair (so 2 pieces) of premium Fischer Elektronik http://uk.rs-online.com/web/p/heatsinks/1898606/ , as you can see it has been slightly damaged in transportation.
* various chinese heatsinks,
* lab mains 19" outlet panel, France pinout, (mounting ears MIA)
* proto / Vero / test boards, 4 single sided and one both sides with pads,
* SMPS Vicor FlatPack VI-RU114-EUUU - 2x 12V 16,7A and 1x 48V4.2A (each outputs 200VA) adjustable in all ways, parallel, series, used for my tests onl
Big resistors, Welwyn mostly, W22, W24 and WH50
* Welwyn WH50 50W 5% wirewound: 15R x4, 10R x6, used by me for test purpose, like new. 10R x2 abd 15R x2 alu case with bits and marks as used and screwed by me.
* Sfernice Vishay RW RB 20.117 wiewound 80W 10R 5%
* Welwyn W24 wirewound 5% 12W 150R x8
* Welwyn W22 wirewound 5% 7W 820R x30
* Welwyn W22 wirewound 5% 7W 12R x3
* Welwyn W22 wirewound 5% 7W 51R x3
* Welwyn W21 wirewound 5% 2.5W 750R x7
* Welwyn W21 wirewound 5% 2.5W 18R x4
* Welwyn W21 wirewound 5% 2.5W 510R x5
* Welwyn WP4S 4W 5% 2K7 x30
* Unknown 1K 5% 5W
* Vishay RWM 3W 5% 51R x10
big film caps:
- * 150uf 63V MKS4 Wima x2
- * 100uf 160V Intertechnic x2
- * 10uf 275V MKP X2 Arcotronics x2
- * 10uf 250V MKT Epcos x6 of wich 2 used for test p2p
- * 4.7uf 63V MKT Epcos x5 out of spec: closer to 4.2uf
- * 3.3uf 400V MKP10 Wima x2
- * 2.2uf 250V MKT chinese brand (industry used) with W brand written x13
- * 2.2uf 250V Vishay 1813 MKT x6
- * 2.2uf 250V Evox MMK x1
- * 2.2uf 250V BC MKT orange x4
- * 2.2uf 160V MKP4 Wima used, x4
- * 1.5uf 800V MKP Jantzen Superior Z x1
- * 1.5uf 400V MKP10 Wima x4 of wich 2 used for tests
- * 1uf 250V Evox MMK x15
- * 1uf 250V Epcos like (double S logo) x2 used for tests
- * 5uf 250V Icel PHC MKP x4
- * 1uf 250V Ero 1813 MKT x9
- * 1uf chinese brand MKT 250V x20
* mint JBL mid-woofer 706G-1 pair
* 3 fired TA3020 amps, I will not investigate to build one out of 3 dead, no thanks,
*16 TO220 like heatsink, as is so a bit tarnished
* L-Pad 8Ω, Monacor, new, x2 (2 sold)
ICs
* Headphone amp chip TPA6120A2DWP x3
Opamps:
SOIC
* OPA827AID x2
* LT1128 x2
* LM4562MA x5
* LML49723MA x5
* LT842 x2
* AD8066AR x2
* AD797B x2
* AD8656 x1
* AD8620 x1
* AD8599 x2
* AD8597 x2
* OPA211 x2
DIP 8
* OPA227P x4
* OPA602BP x2
* OPA2132P x4 (x2 grade A)
* OPA2277PA x2
* AD797ANZ x2
* AD844AN X2
* LT1028 x4
* LT1128 x3
* LT1357 x2
* LT1364 x2
* LT1361 x2
* LME49720HA x2
* LM6171BIN x4
* LM386N-1 x3
Links for HD pictures
https://ibb.co/g1PhX5
https://ibb.co/eUZSzk
https://ibb.co/hhHQkQ
https://ibb.co/eAH2X5
https://ibb.co/fqd9C5
https://ibb.co/mddnzk
https://ibb.co/ksBws5
https://ibb.co/j7eSzk
https://ibb.co/coO9C5
https://ibb.co/ffgws5
https://ibb.co/bDtWQQ
https://ibb.co/hXWJ5Q
https://ibb.co/bw0d5Q
https://ibb.co/fxVNX5
https://ibb.co/ng8y5Q
https://ibb.co/fQNfKk
https://ibb.co/mE8bs5
https://ibb.co/hpmJ5Q
https://ibb.co/dMDbs5
https://ibb.co/bCapC5
https://ibb.co/htP5kQ
https://ibb.co/bsN2X5
https://ibb.co/mAQNX5
https://ibb.co/dqe5kQ
https://ibb.co/jvOWQQ
