FS ESP P101 Amp
I have a completed and working P-101 amp for consideration. Built exactly to spec, but with a lower voltage transformer to experiment into class A.
Anyway, I can replace the transformer to the spec'ed 40VAC to get the 350 wpc class AB as initially designed if requested.
Also considering selling just amp board and/or power supply without chassis (chassis alone cost me $190 from Italy - hifi2000 Dissipante 4U model)
A fine amp and recently upstaged by my new Krell Clone.
Pic to follow later
Luke,
I have sent you an email. The boards work perfectly.
Is there a problem with the power supply that is causing that transistor or channel to blow?
This is preferred as I was looking to reuse the PS and chassis for a Zen Amp anyway...
John thanks for your mail. I think I will try and fix the channel, seems a waste to just pop in a new pair of boards. Im pre plug and play culture🙂
I suspect that although my mosfets seem to test ok, they are the problem, it really cant be anything else cos Ive checked it so thoroughly. Wish me luck, BTW I bought my mosfets from diytech, nice service.
