Electra-Print Audio Co.
Model VT2KB
One Pair (2 matched pieces) Single Ended Output Transformers
about 14 lbs each ( yes, very heavy duty )
$600 per matched pair
it is primary 2.7k ohm with high wattage ( high 160 MA )
Multi taps secondary from 2 ohms to 32 ohms ( color codes available )
for we300b types vacuum tubes ( yes it works with regular 300b tube with better bass )
such as ...
KR 300b 300BXLS KR 52 842 ... Vaic / emission labs VV30b VV52 520b 320b 842 1605 etc
(not limit to, depends on your application, i have tried with all those tubes about up to 30 watt output )
was removed from working amplifiers
so , they are good in working condition ,
will come with new unpainted matching end bells shielded covers
so you can install easily the way you want
with difference position bracket for your need
declaimer .. please be understood that these are amplifier parts, actual application depends on your setting and design spec, however may be able to assist after sales for best of my knowledge
my price is simply including PayPal fee, actual shipping will apply depends on your location
Local pick up welcome ,
Model VT2KB
such as ...
