FS: Earthworks M30BX precision measurement microphone
THIS HAS BEEN SOLD.
Selling my Earthworks M30BX precision measurement microphone. The BX option is battery powered and has very low noise. A removable XLR to RCA converter is also included so that you can connect the mic via an RCA input on your audio interface, if desired. You can always use it via a balanced mic cable and no phantom power is needed. MFG info here:
https://www.earthworksaudio.com/wp-content/uploads/2017/08/Earthworks-M30BX-Manual.pdf
When I purchased this mic in about 2016 I had Earthworks do an extended calibration on it that is valid from 0.1Hz to 80kHz. This was so that I could get reliable measurement data on tweeters up to 80k. I will provide the calibration file to the buyer.
I use other mics for my routine measurements the Earthworks has been used sparingly and always stored in a cool, dry place in its case.
I have the original case and will pack with padding for safe transit. I'm happy to provide pics upon request.
Photos attached...
