FS-DDDac USB dac 1543
ps forget to add that my have a TDA1543 Tower Tooling , 45€ ,add 20 €
total price 90€
only for you woodturner-fran 5€ more ! ie 75total
you only add simple 12vc ,can be simple battery or a regulate psu,
this work
SLA panasonic but there are better ,$$$ like nord star ,search on forum :)
my suggestion is to start with what you have on hand ,better play with output resistor ,the sound change a lot from stock resistor rispect riken holco or kiwane ,my suggestion here is to go for tantaliun shinkoh resistor (hifi collective, 180R)
one question ,your preamp have input caps ?
the dac have 3 dac config :
one on usb chip
one 1543 on usb board
12 1543 on tower board (is config for this one , the better)
as modular ,in future you can add a second tower to improve
PS try add a psu caps in // the battery
Yes, right now I'm using a B1 buffer, so it has a 1uF input cap.
I do have some boards from Promitheus for a pass D1 output stage, which IIRC, is perfectly suited for this DAC. But I need to check that. I should be able to get my hands on some batteries I think. I know I have some nice LiPO ones that I should be able to string together to get 12V.
BTW, this is the MK1 version from the DDdac.de site?
thanks for this info...
Fran
