Buy pre-Conrad-Johnson PV 12L very carefully as you can see in the pictures and works perfectly.
Only I shipments to Europe.
The price is 890€ (paypal) + shipping cost
Specifications: Gain: 47 dB Phono Stage (phono overload at 1kHz 200mV) Line Stage 18 dB Distortion: less than 0.1% THD or IMD Response: 2 Hz to more than bandpass 100kHz RIAA equalization: +/- 0.25 dB (20 to 20 kHz) S / N Ratio: Phono Stage 78 dB below 10mV input Line Stage 92 dB below 2.5 volt output Phase Response: Stage Line inverting phase, Phono Stage Mechanical phase correct: 19 "X 3.15" x 12.5 "
Maybe I'm missing something but why are you stating phono stage specifications when the unit pictured doesn't have a phono stage?
Please clarify. Old CJ link is here: PV-12 Pre-Amplifier
Best,
Anand.
Best,
Anand.
Best,
Anand.
hello, I tried searching online but the specification is complicated, thought were the right ones, but if they are not correct them off.
regards
