FS: "CMOY Killer" Heaphone amplifiers - 500 milliwatts per channel @ 32ohms!
Why do you state "No input or output capacitors needed"? Since there is no servo, if a noob buys this, connects a source with DC offset, and proceeds to fry their headphones; will you reimburse the cost of said headphones?
Supply decoupling looks less than optimal. Did you bother to read the datasheets first?
EDIT: Nevermind about the poor layout, I see you didn't design it. It seems to be the same PCB jims_audio sells.
