FS CE Design ES9018 controller unpopulated pcbs
I have for sale a couple of pcbs for es9018 controller designed by CE DESIGNS.
Unfortunately his site is down for a while .
I`ll do my best to provide a schematic and the working programming code.
The controller is based on atmega644.
It has control over 12 registers of es9018 : fir filter, iir filter, notch, quantizer, dpll, dpll multiplier, oversampling filter, input format select i2s or spdif, input data type rj lj and i2s, src, btm, deemphasis.
It also has support for real time clock(rtc), infrared remote sensor for apple remote and push buttons so you can use it without a remote control.
It is not supporting a rotary encoder.
As for the display I am using NHD-0420DZW-AY5. Did not try any other type so I can not guarantee others will work.
I am asking 4 euros for the single unpopulated pcb.
Thanks.
