Hello,
Now, I have to get rid of this chassis. I will take the best offer ending May 10 at midnight CST, even if only $1. Shipping will be determined based on location, no international shipping though. Local pickup optional.
The chassis is a modified DALAUDIO retro amplifier chassis - Dynaco ST-120. This was never used. It comes as pictured with Sure voltmeter and hardware. Notice the two holes, the smaller hole is roughly 12.25-12.5mm and the larger hole is roughly 22.25-22.5mm; outfit them as you see fit. The chassis was bought new, modded, stripped, and powdercoated. There are slight imperfections in the powdercoating, notice some buildup near the seams for instance. I give the powdercoating a B-. The Sure voltmeter housing has some scrapes on it. It was used to determine size of hole needed. Scrapes are on inside of chassis.
