Used with 120v primaries. Model AT/D3040. No VA rating on label. Ships with hold down cover and bolt, upper and lower gaskets and two bridge rectifiers with heat sinks attached. If you have use make an offer. Heavy, actual shipping cost added. Item SOLD
Hi Paul,
The approximate dimensions are 2 inches high by 4.5 inches in diameter.
Thanks,
Another Paul
Thanks,
Another Paul
I think that means that it is a 250va transformer.
Transformers and Power Converters From Avel Lindberg, Inc.
Parts express has the Y236652 for about $55 plus shipping. How much do you want?
paul
paul
I am asking $20 plus shipping. It is clearly marked 25v + 25v. Thanks for looking up the va rating. Shipping would be from WI.
Paul J.
Paul J.
