FS- Audio Alchemy DTI PRO 32
The Audio Alchemy DTI-PRO 32 is an anti-jitter device for a CD system that improves the realism of CD sound with a voltage-controlled crystal oscillator. It connects between your cd or dvd transport/ player and your DAC. This is more than just a unit to eliminate jitter, it also increases the word length resolution of the signal coming from your transport. You have selectable options from the front panel for different word lengths from 16 up through 24 bit. This unit will also pass HDCD signals (only useful if your DAC accepts HDCD). Comes with outboard power supply. Faceplate is bent on one corner.
Retailed for $1500!! Looking for $150US.
