FS: Amplifier case, front champagne
Housing for amps or pre-amps, in steel with alu front.
The aluminum front is 5 mm thick, the opening is intended for a display, the edge of the volume knob is embedded in the front panel
Please select one of the poti knobs you like(-pictures), color and surface of the knobs and the front panel differ.
The rear panel has factory-installed holes for RCA jacks and LS connectors and a power cord jack.
In the bottom plate are some factory-made holes for the attachment of components / boards introduced.
Supplied with: 4 housing feet / black (about 6 x 2.2 cm / d x h), mounting screws, four RCA sockets, a simple power switch, an adapter plate for attaching the power switch and one poti knob (optional, see above).
height 10.3 x width 43 x depth 33.5 cm
the case is unused, shipping: Germany 6,50 Euros, EU 22,- Euros
non smoking household
ask for 90.- Euros plus shipping
