FS: AMB Gamma2 + O2 amp stack
FS: (Price Drop) AMB Gamma2 + O2 amp stack
Hello,
Currently selling a stack made of the AMB Gamma 2 and the Objective 2 amplifier (the Stack Squared?)
The AMD Gamma 2 was built to spec following AMB's site and is using a Gamma 1 F (Full++) configuration. This means that inside the Gamma 2 enclosure there's:
USB, coax and S/PDIF inputs (selectable) and coax and S/PDIF outputs
USB to coax/S/PDIF converter
One WM8501 DAC that can receive up to 24bit 96kHz (analog output 1)
One WM8741 DAC that can receive up to 24bit 192kHz (analog output 2)
Digital filter selector
The first output can be used to drive headphone directly. The second output is of higher quality and is meant to be used to feed an amp. The DAC will be shipped with dust covers for the RCAs.
More at:
The γ2 compact high performance DAC
The O2 is the usual suspect, but this one is wired and has panels for being used as a desktop amp:
6.35mm output jack
Input RCAs and output RCAs
No batteries
A power supply will be included for the amplifier. For the DAC, you can power it directly from USB, or use a 5V 300mA power supply.
I am asking for 250€ plus shipping for everything, or 200€ for the DAC and 80€ for the amplifier.
Pictures below (white credit-sized card for size comparison):
