For Sale FS: AMB Gamma2 and O2 stack
Things you have for sale.
Hello,
Currently selling a stack made of the AMB Gamma 2 and the Objective 2 amplifier (the Stack Squared?)
The AMD Gamma 2 was built to spec following AMB's site and is using a Gamma 1 F (Full++) configuration. This means that inside the Gamma 2 enclosure there's:
USB, coax and S/PDIF inputs (selectable) and coax and S/PDIF outputs
USB to coax/S/PDIF converter
One WM8501 DAC that can receive up to 24bit 96kHz (analog output 1)
One WM8741 DAC that can receive up to 24bit 192kHz (analog output 2)
Digital filter selector
The first output can be used to drive headphone directly. The second output is of higher quality and is meant to be used to feed an amp. The DAC will be shipped with dust covers for the RCAs.
More at:
The γ2 compact high performance DAC
The O2 is the usual suspect, but this one is wired and has panels for being used as a desktop amp:
6.35mm output jack
Input RCAs and output RCAs
No batteries
A power supply will be included for the amplifier. For the DAC, you can power it directly from USB, or use a 5V 300mA power supply.
I am asking for 190€ plus shipping for everything, or 160€ for the DAC and 50€ for the amplifier.
Pictures below (white credit-sized card for size comparison):
The AMB Gamma 2 offers in a single compact package two high quality analog outputs, three types of digital inputs, a simple digital to digital converter (TOSLINK or coaxial output), different digital filtering. And it's not much bigger than a credit card!
The O2 at 50€ is the perfect entry amp to give away to someone, or keep at the work desk. It comes included with the power supply. In a desktop variant build.
