FS: Aluminium amplifier enclosure.
Bought this for a project and ended up ordering something else as this had been missing in the parcel service for 3 months.
No longer needed and unopened.
Ill add dimensions later today.
£140 delivered in the UK
Specific structural dimensions:
External dimensions: width= 432mm , Height= 110mm , Depth = 312mm .
Internal dimensions: width= 325mm , Height= 100mm , Depth = 300mm .
The Front panel : Thickness: = 8mm .
The Rear panel : Thickness: = 4mm .
The Top panel : Thickness: = 3mm .
The bolew panel: Thickness: = 3mm
Ill do £130 delivered in the UK
Big MoFo [emoji16] 24V 2.5A 60W dissipation per channel, so really 0.42 is on the edge, I prefer safety to surprises so would prefer below 0.4 oC/W. Also fitting the 193V inductors into that case would involve shoehorning them in sideways mounted on the back plate with not quite 5mm spare, and they would have to sit on the aluminium brackets...
