Hi All,
Any interest here for a pair of Acoustic Elegance TD15H drivers?
They are well reviewed for their excellent power handling, high x-max, lower inductance, etc..
My price is $475+shipping. New, they are $700+shipping (and few months wait).
See specs below:
TD15H-8ohm
Fs: 21Hz
Qms: 4.23
Vas: 467 L
Cms: .45 mm/N
Mms: 129 g
Rms: 4 kg/S
Xmax: 14 mm(peak)
Xmech: 20 mm(peak)
Sd: 855 sqcm
Vd: 2.4L (p-p)
Qes: .27
Re: 6.5 ohm
Le: .3 mH
Z: 8 ohm
Bl: 20.1 T/m
Pe: 500W (cont.)
Qts: .26
1WSPL: 94 dB
2.83V: 94.84 dB
See specs below:
TD15H-8ohm
Fs: 21Hz
Qms: 4.23
Vas: 467 L
Cms: .45 mm/N
Mms: 129 g
Rms: 4 kg/S
Xmax: 14 mm(peak)
Xmech: 20 mm(peak)
Sd: 855 sqcm
Vd: 2.4L (p-p)
Qes: .27
Re: 6.5 ohm
Le: .3 mH
Z: 8 ohm
Bl: 20.1 T/m
Pe: 500W (cont.)
Qts: .26
1WSPL: 94 dB
2.83V: 94.84 dB
