BRAND NEW in box.
15" with Aluminum phase plug
4 units US$1100 + shipping & Paypal
These are 8 ohms drivers per the specs below:
Dipole15-D8
Fs: 21.7Hz
Qms: 15.2
Vas: 623 L
Cms: 0.6 mm/N
Mms: 90 g
Rms: 0.81 kg/S
Xmax: 12 mm(peak)
Xmech: 18 mm(peak)
Sd: 855 sqcm
Vd: 2.06L (p-p)
Qes: 1.00
Re: 3.08 ohm (parallel)
Le: 0.04 mH (parallel)
Z: 4 ohm (parallel)
Bl: 6.1 T/m
Pe: 100W (cont.)
Qts: 0.94
1WSPL: 90 dB
2.83V: 94.2 dB
Dipole15-D8
Fs: 21.7Hz
Qms: 15.2
Vas: 623 L
Cms: 0.6 mm/N
Mms: 90 g
Rms: 0.81 kg/S
Xmax: 12 mm(peak)
Xmech: 18 mm(peak)
Sd: 855 sqcm
Vd: 2.06L (p-p)
Qes: 1.00
Z: 4 ohm (parallel)
Bl: 6.1 T/m
Pe: 100W (cont.)
Qts: 0.94
1WSPL: 90 dB
2.83V: 94.2 dB
