I've had these for a couple of months and used them in this project , where they worked extremely well as mid-basses in a shallow u-frame. They are all essentially like new.
Specs can be found here and are as follows:
FS 40 Hz
RE 5.6 ohms
Qms 2.73
Qts .44
Qes .526
Xmax 7.8 mm each way
L (1k) .86 mH
L (10k) .36 mH
Vas 34.57Liters
Ms 11.9 grams
Cms 1.3183 mm/newt
Bl 5.66 Tesla-M
SPL 88.3 db
Area 137.7 sq cm
Asking $30/each
FS 40 Hz
RE 5.6 ohms
Qms 2.73
Qts .44
Qes .526
L (1k) .86 mH
L (10k) .36 mH
Vas 34.57Liters
Ms 11.9 grams
Cms 1.3183 mm/newt
Bl 5.66 Tesla-M
SPL 88.3 db
Area 137.7 sq cm
Asking $30/each
gitarretyp said:I've had these for a couple of months and used them in this project , where they worked extremely well as mid-basses in a shallow u-frame. They are all essentially like new.
FS 40 Hz
RE 5.6 ohms
Qms 2.73
Qts .44
Qes .526
L (1k) .86 mH
L (10k) .36 mH
Vas 34.57Liters
Ms 11.9 grams
Cms 1.3183 mm/newt
Bl 5.66 Tesla-M
SPL 88.3 db
Area 137.7 sq cm
Asking $30/each
Seen you at Open Baffle, just curious if it works well why you are selling them?
