FS. 2 KVA TOROIDAL TRANSFORMER
I have one very large toroid power transformers 2000VA from an amplifier project. It is in excellent shape., and has a dual output,with:
In: 0 - 220 - 230 VAC 50-60 hz (It can work on 240v but will slightly increase and the output)
Out: 75 - 37 -0 - 37 - 75 V
Outputs can be separated.
Very lite used on H class amplifier test bench (supply from variac)
for less then a month, and never it is being loaded more than 1KVA.
Dimensions : D-200mm H-90mm
Weight : 16 KG.
Price: 80,00 Eur + shipment cost from Greece
