From AA 4/82 "A Tangential Tracking Tone Arm" Kit
This kit tone arm was published in Audio Amateur 4/82 and I got one in a trade
still in the box. I'm wondering if anyone has built it, seen it work, or heard
anything good/bad about it?
I looked over the documentation and remember reading the article when it came out.
What I like about it is that it has a pivot like a normal arm but with photo sensors for
when it goes even slightly off linear which are used to ramp up or down the servo
speed. This way if the servo fails it just works like a normal arm but with the usual
tracking error, the bearing also, sort of decouples the arm from the servo movement.
Clever, I like that aspect.
I have not assembled it as I was asking to determine if it is worth the time.
Here's the picture:
attachment.php
Yes, I do. I fell for this same post over on another forum. I scanned and posted the entire aa 4/82 construction article in response, with nary a comment or thank you.
Looks like the moderator(s) over there took the thread down.
Ray K
Thank you, have you built it?
Nope. At the time it was published, I already had 2 Rabco tangent trackers that worked fine, so had no need.
Just happen to have every issue of TAA, so when someone is looking for an article, I'll try to oblige.
It's an intriguing design though, servo that runs at nominal groove pitch so no major dithering, and the unusual optical trigger method.
You're the guinea pig🙂. Get 'er built! Let us know how it works!
Reading the article reminded me that this was also in Wireless World.
This post by Trad at VA seems to confirm it:
References on DIY tonearms:
1. R. Cooper, A Tangential Tracking Tonearm, The Audio Amateur, 4/1982 (also reprinted in The LP Is Back!).
2. D. Read, Simple Pickup Arm Design, Wireless World, November 1980.
3. R. Cooper, Practical Parallel-Tracking Pickup Arm [Part 1], Wireless World, December 1979.
4. R. Cooper, Practical Parallel-Tracking Pickup Arm--2, Wireless World, January 1980.
5. R. Cooper, Mercury Switch for Parallel-Tracking Pickup Arm, Wireless World, April 1980.
6. R. Cooper, Parallel-Tracking Pickup Arm Modifications and Improvements, Wireless World, July 1981.
7. E. Lowinger, The Bizarm, Wireless World, December 1977.
8. D. Ruether, The Praying Mantis, The Audio Amateur, 2/1976 (also reprinted in The LP Is Back!).
9. R. Sanders, A Do-It-Yourself Tonearm, The Audio Amateur 2/1973 (also reprinted in The LP Is Back!).
10. D. Bartholomew, Unipivot Arm, Hi-Fi News & Record Review, April 1972.
11. R. Ockleshaw, Pickup Arm Design for Home Construction, Wireless World, November 1971.
12. J. Bickerstaffe, Building the Woggle Arm, Hi-Fi News & Record Review, October 1971.
13. J.S. Wright, Approach to Pick-Up Arm Design, Wireless World, June 1967.
14. J. Bickerstaffe, Torsional Stability and the Unipivot, Part 1, Wireless World, January 1966.
15. J. Bickerstaffe, Torsional Stability and the Unipivot, Part 2, Wireless World, February 1966.
Reference [11] is in fact one part in a three-part series describing the construction of not only an arm but also a turntable (using a factory-made platter) and a wow & flutter meter. The other two parts are:
16. R. Ockleshaw, Turntable Design for Home Construction, Wireless World, October 1971.
17. R. Ockleshaw, Novel Wow and Flutter Meter, Wireless World, December 1971.
Even if one is not contemplating the actual construction of a tonearm, it is fascinating to read about the various designs. It goes without saying that for anyone seriously thinking of building a (pivoted) tonearm, the classic papers by Lofgren, Baerwald, Bauer, Seagrave, Stevenson and/or Randhawa on tonearm geometry are required reading.
I remember reading one of the original articles in Wireless World in a magazine store in Boston in 1979 - I assume it was R Cooper's. I was aflame to build it, but had none of the skills or equipment necessary. But as a kit, it would be a no brainer whether to build it or not.
I hope you build it, Pete.
Here's the picture:
attachment.php
I realize this is a bit late but I just found your question. I built this arm in about 1980 and it’s been working perfectly ever since! I attach a recent photo
@houltd What cartridges have you run on it and will it track at 1g if the cartridge is capable enough?
It looks as if it works best with an un-sprung chassis since there are two mounting points to the table,
is that correct?
I see mention of using very flexible litz wires do they just hang below the arm or anything special to feed them below the table?
Thanks very much for posting.
